2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Setting the clock
Old Aug 29, 2007 | 9:35 AM
austin85impala's Avatar
Default Setting the clock
Hi I'm new to this forum. I just bought an 85 Impala 305ci 5.0. Completely original. This was grandma's car and has been sitting in the garage for a minute. How do I set the Clock? There is a small hole under it and I've put my finger up in there and tried feeling around for something like a dial but nothing happened. Any information is great. I will be posting more questions here soon as I start fixing up the ride a bit. Thanx.
Old Aug 31, 2007 | 7:14 PM
Foxracing's Avatar
Default RE: Setting the clock
I'm not sure without actually seeing the radio, but if I remember, turn off the radio, and then push in on the *****. As said it's been awhile, if you could show a pic, that would help.
Old Sep 1, 2007 | 9:49 AM
I clock I am having the issue with is located in the dash. It is a Quartz Analog Clock
Old Sep 1, 2007 | 10:59 AM
n7jpq's Avatar
Also the version where you gently pulled out on the seek and scan buttons. 1 was hrs, other minutes.
Jim
Old Sep 1, 2007 | 11:02 AM
n7jpq's Avatar
Can you gently pull out the stem and rotate it.
Jim
Old Sep 2, 2007 | 6:46 PM
Foxracing's Avatar
Is there any very small holes @ the clock? If so, a pen can be used to gently press to change time?
jepurl
Nov 23, 2008 2:59 PM
haidangwa
Jun 21, 2007 11:02 AM
deejayrock
Apr 21, 2007 8:31 PM
leeperkins7
Nov 5, 2006 9:51 AM
bsmith51
Oct 8, 2006 12:43 PM
