Transmission prob 2013 impala LT?
I have a 2013 impala LT with 57k miles. Last wk I got my oil and air filter changed at valvoline. They recommended a transmission flush but I declined, since then my engine light has been on and my fan belt continues to run when I turn my car off. Today they car stopped on me while I was driving, but started right back up when I started it back up. Any ideas what could be going wrong?
I would have it scanned for codes and then proceed on from there....
hard to say without codes but if its only been happening since they changed the air filter i'd make sure they got everything put back together and tight, also that they didn't leave the mass airflow sensor unplugged some reason
I used one of those places once, they left the cap off my coolant reservoir and I almost overheated it 10 minutes after leaving the place while sitting in a traffic jam.
I'd give a good look under the hood and make sure all the caps are secured on your fluids and the dipsticks are seated as well. And while you are checking the caps, check your oil and coolant and also take a look at your belt. |
Originally Posted by U.Nanimous
(Post 311873)
