1994 K5 ABS question
So the ABS, 4wal, hasn't been working for quite sometime. Watched a bunch of videos on deleting the ABS but before that trying a few more things. Here's the question : Hubs with internal speed sensors replaced the original equipment years ago. Not sure when the ABS stopped working properly but i did replace the giant ABS module last year and it is getting power.
Can hubs with the built in speed sensors work for this year Blazer or could that be my problem and i need to return to OEM equipment? I haven't found a definitive answer online but the consensus says no. Has anyone had experiences with newer hubs one way or the other that work? Or any advice would be helpful. ** also figured out why my ABS light isn't even on... someone took it out. I'm guessing in the 3 years before our family bought it (we got it in '97) |
Okay i'm not seeing an "edit post" button so i'll just do this. ABS light installed, comes on when starting the car then goes off like nothing is wrong. The ABS module has power. Could this be an actual brake issue (calipers etc) or the hub isn't working as intended?
What's it doing when you say not working? In my 93 after start up, once going forward you could hear the abs motor cycling - is that happening?
(Post 516043)
So using my 93 Sub to compare - when you start up and put it in drive and start to go, I hear the ABS motor run - like a loud buzz/hum for approx 5 sec - very obvious. Happens at about 5mph. When you slam on the brakes you should also hear it and feel obvious pulsations in the brake pedal. Mine has not worked for years so brakes feel/work like a standard non-ABS vehicle.
(Post 516045)
| All times are GMT -5. The time now is 1:13 AM. |
