Hi Everyone, Im looking for Mechanic in O.C Cali for Help
I have an 88 K5 blazer that is more project than i can handle but i would really like to have someone finish for me. Basically needing the motor install completed and dialed in. Someone knowledgable no BS. Truck is in my garage in Orange Ca. if that works for you shoot me an email and we can work out the details.
basically I had a toasted wire harness, shot motor, so I dropped in a newer motor w.ecm and harness from a 87 suburban and I have gotten as far as wiring all to the firewall on the motor but the dash stuff still needs to be done, plus the tranny is missing some bolts and stuff that need to be finished up., Anyways if your up for the job let me know |
RE: Hi Everyone, Im looking for Mechanic in O.C Cali for Help
For future reference, you should post tech questions, in the Tech section. This is the new member area, where you come in to introduce yourself, if you want a good result to your question then I suggest asking it in the correct section or the right person may never see it.
Sorry about that and thanks for the advice. I dont want to double post so maybe the moderator can move it
No problem, Brent should be able to move it.
Got it moved.
Welcome to the Cheverlot Forum!!!
_____________________________ Chevrolet Extended Warranty - Are you covered? Are your other GM vehicles covered with a General Motors Protection Plan (GMPP)? |
