-   Malibu (https://chevroletforum.com/forum/malibu-15/)
-   -   06 SS engine code (https://chevroletforum.com/forum/malibu-15/06-ss-engine-code-39823/)
vortec02 Jan 31, 2011 9:04 AM
06 SS engine code
hey guys i got an 06 SS with 3.9 have a p2070 code
says intake man tuning valve stuck open doesnt seem to affect anything except when the ce light is on the remote start wont work. :( also im gettin ****ty gas mileage where is this tuning valve?? and can it just be cleaned out or should i replace it??? thanks
vortec02 Feb 1, 2011 10:23 AM
ok i did some research i found where the valve is now all i need to know is can it just be cleaned out ?
Jo Palker Aug 24, 2012 12:53 PM
how did you fix this
tech2 Aug 25, 2012 5:47 AM
there is a bulletin to inspect for a missing bushing that supports one end of the valve. If its missing the fix is to replace the entire valve assembly.
if the bushing is in place; its either wiring, ecm or the valve itself...the valve being the most likely problem.
Check the fuse that supplies power to the valve as a start.
