1997 Malibu starting issues
I have a starting issue w/this car. Sometimes the car flat out won't start and the theft system light will come on and blink for about ten minutes and then it shuts off and I can usually get the car to start. Regardless, the car always starts rough and it does not matter what key I use it is the same. I have been told that the ignition switch is going bad and can't always read the chip correctly that is built into the key. Even when I am driving down the road the theft system light will come on, and the car will still run fine. I have replaced the fuel regulator and spark plugs and wires and the problem still persists. Who agree's that this is a ignition switch problem?
Thanks, RC |
RE: 1997 Malibu starting issues
I am having the start problem with my 03 malibu. I am doing research on the internet now about this problem.
How did you finally solve the problem? Can you share with us? |
| All times are GMT -5. The time now is 3:07 AM. |
