2004 hazard switch replacment help
my signals are all messed up and the bulbs are still good i was told to replace the hazard switch,is there a video or how too on this job,i could you,s help.
thanks:confused: |
very easy to do. the trim piece around the hazard switch on the dash needs to be pulled off. pull gentle, starting at one side. the switch is attached to that piece. remove and replace.
ok did it and there still messed up.
are there any other problems? just turn signal?
replaced a blown rear bulb now they all work except for the front amber running light,i was driving today and my daytime running helights went off and the 2 front amber side markers came on,then when i restarted the car the headlights came back on and only 1 amber side marker light in the frot came on.
well 1 week later and the front passenger turn signal bulb is out again,wow.
