2005 Malibu fuel gauge problem
hi, ive noticed some similar problems around the forums, but no responses to them.. i just hope someone can help me with this one.
recently, after i fill up my car about a minute or so into the car being on, the fuel gauge drops from full to empty, and sometimes the check engine light comes on. But after maybe an hour of driving (or less i haven't actually timed it) the fuel gauge is back up to full and starts to function as it should. this only happens when i fill up when the low fuel light comes on, it doesn't happen when i fill up from 1/4 tank or above. thanks for any help you guys can give, i really don't want to take it into a dealer... |
I would first check all in wires and connections to the sending unit. If they are all good I would change the sending unit.
2005 Malibu Fuel Level Sender Fix - Beating the System
One day the fuel level sender in my 2005 Malibu failed, alternating from full to empty, and causing my check engine light to come on. I chose not to fix it for a while - given the cost and hassle - and just calculate fuel use by mileage. I figured, why bother going through all the hassle of dropping the tank and changing the sensor if my fuel pump is still good? Well, some months passed and the car came due for inspection. I live in Massachusetts and to get the car to pass inspection, no error codes can be present in the computer. Here's what I did to make it pass inspection for under $2: Trick the computer with a 100ohm 1/8 watt resistor from Radio Shack. Here's how I did it: At the fuel tank electrical connector block under the car near the tank, find the purple wire (fuel sender) and the black wire (ground). In the back of the connector (the side which leads up to the front of the car, NOT the side that leads to the tank), take a sewing needle or small awl and clear paths for the resistor leads to slide in past the wire seals and make contact. Carefully slip the 100ohm 1/8th watt resistor into the spaces next to the wires, connecting the purple and black wires with the resistor. Next, open the connector and check with a multimeter that there is continuity between the connector pins and the resistor leads on the back of the connector. Reconnect and turn the key to the on position. The fuel gauge should now be reading about 1/4 tank - a reading it will have permanently. To finish the job, put some RTV silicone on the contact points of the resistor and plug to keep water out. Blast the code from the computer if you want. If you ever change the sender, remember to take the resistor out! Disclaimer: Enjoy this cheap fix, and understand that I take zero responsibility for the information, and do not recommend that you actually do this." Keep it real, -M@ |
| All times are GMT -5. The time now is 11:12 PM. |
