AC not blowing cold
Malibu 2006 LS
for last several months, when I turn my AC on (push the button, temp knob is already turned all way to left/cold) it will blow hot air. if I then turn the temp knob all the way to right and then back to left, cold air will begin blowing. if I position temp knob in middle or all way to right with AC off, then turn on AC, then turn to left, it will blow cold. In addition to above, I noticed the air slowly being less and less cold, even with knob at full left. And now today at lunch, with outside temp at 90deg, it would not blow cold at all, regardless Patrick |
I would check the blend door and actuator.
| All times are GMT -5. The time now is 11:28 PM. |
