Temp Gauge 2005
My 2005 Malibuhttp://images.intellitxt.com/ast/adTypes/icon1.png Maxx LT's temp gauge stopped working last night. The fan still seems to be working when it needs to and the air is still hot from the heater.
I have 5V across the pins to the ECT. Is this the same sensor that runs the gauge? Or is there a separate sending unit? If so where is it? |
data from the ect sensor is read by the ecm and sent via serial data lines to the instrment cluster.
a fault in the ect sensor should default the temp guage to 100'F and set dtc in the ecm. What is the guage reading when the fault occurs? key on engine off, you should have 5volt on the yellow wire. grd is provided on the orange/black wire via the ecm. Disconnecting the harness to the ect sensor should make the guage read max cold with key on engine off. jumpering the connector terminals should make the guage read max hot, koeo. |
Originally Posted by tech2
(Post 233577)
a fault in the ect sensor should default the temp guage to 100'F and set dtc in the ecm. What is the guage reading when the fault occurs? key on engine off, you should have 5volt on the yellow wire. grd is provided on the orange/black wire via the ecm. Disconnecting the harness to the ect sensor should make the guage read max cold with key on engine off. jumpering the connector terminals should make the guage read max hot, koeo. The engine constantly runs as if it is cold, but the fans run too. I have heat inside the car as well. Jumping the wires causes no change. Neither does any disconnect that I can easily do. I just replaced the sensor and no change at all. Any further hints? I am working blind without a manual or diagram on this car. |
if the guage is bottomed (reading cold) and you have already replaced the sensor; the wiring is open.
Grd the yellow wire and see what the guage does, it should go full hot. If it does 5 volf ref wire is good and the grd wire is open. Check the grd circiut again. if your sure the grd wire is good; connect everything back together and observe the temp reading with a scan tool. If its reading ok with the scan tool, the stepper motor in the ipc (cluster) could be bad. Do the guages do a needle sweep at key on? |
(Post 233593)
Very useful info. Hope to see more posts soon!
| All times are GMT -5. The time now is 5:32 AM. |
