High-efficiency Lumen truck bed LED lights for Silverado at CARiD
Former Sponsor
If you use your truck for work and often get to work in the dark - ease up your life by having Lumen 8-Pod White LED Truck Bed Lights installed and find the belongings you need easily no matter the time of the day. Each set comes with 8-Pods, that has 6 super-bright LEDs, push-button on/off switch and hardware required for successful installation. Lumen lights are extremely vibration resistant and waterproof, they can easily withstand everyday abuse and will work ideally even in a heavy downpour.
Features:
8 light modules that have 6 super-bright LEDs each;
Pod dimensions: 1.45” x 1.06” (37mm x 27mm) stainless steel casing with screw taps;
Push-button on/off switch;
Wire clips/hooks for efficient wire routing;
3M adhesive backing on pods, switch, and wire clips/hooks for quick and secure attachment;
Waterproof;
Great for use with tonneau covers;
Lumen® TRB-POD-BLK - 8-Pod LED Truck Bed Lights at CARiD
Illuminate the entire bed of your truck with Lumen.
Features:
Waterproof;
