1996 Lumina 3.1 Stalling Issues
My issue is that my car keeps shutting off when I'm on the brakes to long or at the light for to long. It can't idle longer then 2-3 minutes. The air sensor was replaced. I had somebody tell me it was the main computer at fault. So I replaced the computer, and the service light went off and the car worked great, it stopped stalling and I could idle fine. But out of nowhere after two hours of driving the service light came back on and the car started stalling once again. So I thought I would finally ask for help online. Thank you
But you hit it right on the head , brakes -> more likely vacuum problem .
My 96 Lumina ( when I started tracing down vacuum lines ) proved to have an absent vacuum reservoir ! No answer for that , I bought the car used in the late 1990's .
God bless
Wyr
And / or loose , defective , or otherwise messed up sensors , wiring or connecters .
My 96 Lumina ( when I started tracing down vacuum lines ) proved to have an absent vacuum reservoir ! No answer for that , I bought the care used in the late 1990's .
God bless
Wyr
God bless
Wyr
original poster should look for dry rotted vacuum lines too.
Danman2897
November 1st, 2012 4:26 PM
Neverdone
Silverado & Fullsize Pick-ups
11
April 17th, 2011 10:58 AM
lovesmonica
March 22nd, 2011 8:02 PM
bjthebetsig
August 26th, 2006 12:24 PM
