1999 chev. 3.1 engine lumina ac problems.
ac quit one day. would low coolant level stop ac from working? the low coolant light stays on even when the coolant is not low does not show dtc problem for low coolant.
Originally Posted by lgaudet
(Post 253922)
If this fails , try disconnecting the negative battery cable , to try to reset the coolant lite . Then come back with an update & discuss the A/C problem ( does the compressor clutch engage when you turn the controls on , on the dash ? ) . God bless Wyr |
how do i get my tie rod out of my 01 lumina 3.1 motor i trued the tool but it has ano
How do i get my tie rod out of my 01 lumina iv tried the special tool the tie rod is factory its bot tge new kinds
Plz someone help me i cant get no wrenches on bback of tie rod
| All times are GMT -5. The time now is 4:25 AM. |
