95 Lumina 3.4 no reverse and loud knocking
Hi All,
Happy Holidays!! Got a call from my nephew yesterday. He was ready to return from college for the holiday. Started his 95 Lumina and engine has a loud knocking noise and transmission would not go in reverse. He's not mechanical. He couldn't back out of his parking spot. Had him towed to his house about 60 miles. Took a quick look last night. Started the car fine. Loud knocking noise from around the engine, back middle or back right hand side. Thought he was low on oil but all fluid levels OK. Initially thought it was the engine, but further looking reveals the following. Transmission shift lever will go to Reverse but car will not move backwards. No movement at all, doesn't feel like it engages. Engine knocking still present. Moved to Neutral - same results. Moved to Drive and the car moves forward and appears OK. Knocking noise disappears!! Going to test drive it today if the rain stops, just to see if it will drive forward on the road properly and shift through gears. Will not let him drive it until this is fixed. Have any of you seen this problem - Loud knocking noise going away when in drive? It seems to me to be the transmission. Is it shot? Could it be something simple I could fix for him? I am a little mechanical but ignorant on transmissions. Any ideas or help would be appreciated. Thanks |
, Dude, I can't believe nobody replied to your initial inquiry.My best to you but it looks as though you decided to goanother route.
Originally Posted by pitbull438
(Post 267989)
Heck, he didn't even reply to what they did to fix it or found out, so why should anyone else care? :confused: |
Hi pitbull, Thanks, I couldn't believe no one answered either. But that's the way it goes. I ended up replacing the transmission and my nephew is all set. Thanks for replying to my op.
and sledge, you were a great help, thx |
