99 Monte ABS and Dash Brake light
Hi Gang!
ABS lightcame on and 2 hrs later the red Brake light on the dash also lit up. OBD2 reader indicates no codes set at all. Any thought? Perhaps a bad ground? Thx in advance Kelly |
RE: 99 Monte ABS and Dash Brake light
Is the brake fluid full?
Fluid is full. Pads are in good shape as well as the rear brakes are in good shape. Emergency brake is off. Thx for the help so far.
