Chevy 3.1 stalls when put in gear when engine warm
I've been fighting this issue for a week now, and I'm at odds where to go now. A week ago, driving home, the tach started to drop quickly to zero then recover, like the ignition was turned off and then back on. I was able to make it home. The car was due a tune up. I replaced the crank position sensor (OEM), replaced sparkplugs (Autolite Iridium), air filter, fuel filter, no help. I ohmed the coil packs, secondary resistance showed good, replaced the ignition control module (aftermarket). After this, engine would stall after it was at temp, could restart, once put in gear it would stall, but I could go in reverse and drive home backwards (LOL). Reinstalled original OEM ignition control module. Towed to GM Dealership, mechanic said fuel pump was bad, ignition wires needed replaced, one injector ohmed bad. I took car home, replaced fuel pump (OEM), ignition wires (OEM), no help. Removed plenum, found pcv valve clogged, and hose kinked, replaced both, ohmed all 6 injectors, 5 injectors read 12.3 ohms, 1 injector was 11.6. Replaced all 6 injectors, (Napa), plenum gasket, still same problem. GM dealership said computer said no data, they though perhaps ignition control module was bad, but I don't think so. I hooked up my Actron shorting plug, reads code 12 which means no faults, no other codes. I noticed EGR valve has a lot of carbon in the hole, thought about changing it, but I'm really not sure where to go now. The car is a 1994 Chevy Lumina with 230,000 miles, spent about $500 the last week doing brakes, and tryng to fix this engine. Need some advice where to go from here.
