how many psi do lumina injectors run
I'm building my own fuel injector cleaner and want to know how many psi it takes to open the injectors. Thanks in advance
Wow no one knows??
No, it's more like you don't seem to understand what you're asking. Are you trying to pressurize the fuel injector on the fuel supply side until the fuel injector sprays? What do you think the electrical connector is for?
Well you c I want to know how many psi they can take so I don't ovr pressure them and wreck them if that's possable.
Without knowing what exactly it is that you're rigging up, I suggest not to exceed the nominal key-on-engine-off fuel pressure of the vehicle the particular injectors came out of.
1 Attachment(s)
Originally Posted by EinST
(Post 196355)
I don't know what you mean by "fuel pump pressure" but if you were to disconnect and block the fuel return line, you shouldn't exceed the nominal KOEO fuel pressure.
(Post 197454)
