Keeping tire lettering white
I recently ran across an article about keeping your white letters white so I'll share some of the content in paraphrase form.
Most tires, after a few years of age, start to fade or yellow. Tires that are used every day tend to pick up raod grime and look dingy and dirty. There are a few steps you can take to whiten them. So here are some tips about different things to use and what they do to the rubber. -Whitening by a strong bleach will fade the black rubber on the rest of the tire, don't use it. -**Degreasers (greased lightning, etc)work well but after many times of use it will start to dry rot the rubber because it is a chemical that works against petroleum. -**Laquer thinner is by far the best at whitening, but it must be applied only to the letters themselves and without scrubbing.**[*]-Mineral spirits works with no majorside effects to the rubber. -Bar soap is a good thing to use, but requires a lot of scrubbing. -Tire bleach (Wesleys Blech-White, tire clean, etc) is great at cleaning the tire, but not whitening the letters if they are extremely filthy -Shoe cleaner/glass cleaner or anything with mild amounts of ammonia work very well. -Never use Varsol. **Care should be taken around aluminum and alloy wheels and all painted rims. |
RE: Keeping tire lettering white
ORIGINAL: EuroGoldLS-Tire bleach (bleche white, tire clean, etc) is great at cleaning the tire, but not whitening the letters. |
Neither do I, but I wash workvans too...
i just use the papertowel i cleaned my windows with and it works great- little bit of window cleaner does a great job
I know duplicolor makes a paint marker so you can paint your letters white, yellow, or red
You won't get good results from those. They make a mess if you are not careful.
Is it very permanent?
I used them on the old set of goodyears I had. The right rear had some curb scarring, so I went over it with the pen. It wroked really good, but it was splotchy and I put it on too thick in places, it ran when the water hit it and then stained the whole tire a grayish color. The lettering stayed white a long time though.
I have always had my lettering snow white using Westley's Bleech White. It seems to work pretty good for me. Then I wipe the tire down with Mothers Back To Black because it seems so get the tire real black and not give it the ghetto supershine look.
Just my opinion. I am not a professional detailer and there might be something better out there. |
