-   S-10 & Blazer (https://chevroletforum.com/forum/s-10-blazer-20/)
-   -   1996 headlight problems (https://chevroletforum.com/forum/s-10-blazer-20/1996-headlight-problems-15567/)
joshuaboudreauxksig May 2, 2008 5:24 PM
This problem may have been resolved on this forum before, but I could not find a search forum option.
I own a 1996 s10 with sealed beam headlights. I would like to install xenon bulbs, but with sealed beams i would have to order whole new headlights. which isnt a problem, id like to order the projector head lights, but the h4 xenon bulbs that supposedly fit the composite headlights on this model, will not fit my connector on my truck. the three prong connection on the truck is off set compared to the three prong connection of the bulb.. any ideas on what i can do?
thanks in advance.
EvansBlue May 3, 2008 12:11 PM
RE: 1996 headlight problems
Search function is located at the top of the forum under the Corvette Picture.
You can always just wire in the connector for the composite headlights. Just figure out which one is ground and which one is low and high beam.
joshuaboudreauxksig May 3, 2008 7:21 PM
Thanks. I figured that was my only option. Just making sure there wasn't another way that I was overlooking. Thank you.
EvansBlue May 4, 2008 4:06 PM
Its a fairly easy mod. I'm 90% sure that you will need the type-A grille to make it work also.
