2000 S10 Starting issue.
Only when the truck has been ran that day. Some times it takes a sec to start. The work done to it is as follows
New Fuel Pump New Fuel Filter All Fluids changed Oil Filter Air Filter. New coil New wires new plugs Belt Alternator Battery Can make a youtube vid if it helps It runs great tho.....:confused: |
Does it run rough for the first couple of seconds right after it starts?
Nope runs perfectly smooth. No miss or shakes.
Have the ignition module checked for failure. I had a simular issue, after replacing the what I thought was a coil issue the same thing occured, then come to find out it was the eginition module, which sits right next to the coil. Little Black Flat Heatsink looking thing.
should look like the link below. http://www.autopartswarehouse.com/sk...%26+Drivetrain |
Originally Posted by Siliconasp
(Post 117930)
should look like the link below. http://www.autopartswarehouse.com/sk...%26+Drivetrain is there a way to test this?? so it would be pointless to clean the injectors? I thought maby it was the injectors but this makes more sense it runs to smooth to be dirty... |
http://www.ehow.com/how_4422228_chec...on-module.html
that ignition module was a link purely for visual reference. Not to order the part. the above like will walk you through the testing process of the module. http://www.autozone.com/autozone/cat...uestid=1927311 this should be the one you need. |
(Post 117965)
that ignition module was a link purely for visual reference. Not to order the part. the above like will walk you through the testing process of the module. http://www.autozone.com/autozone/cat...uestid=1927311 this should be the one you need. You have been a big help! |
Originally Posted by itsmacintosh
(Post 118023)
Sweet THANKS Bro! :D
| All times are GMT -5. The time now is 1:10 AM. |
