2002 s10 pickup
Check engine light comes on. Scan tool says temp sending unit low voltage. I put in new sensor and light still comes on with same code. Any body have any ideas?
Check the wire going to the sensor. it may have a loose connection to the plug at the end. Also check it as far back as you can.
Thank you I will give it a try
