98 s10 applying brake engine starts
So I'm new to this group I own 9 s10 and blazer I have a 98 2.2 auto the ignition was stuck yesterday when you turn it over it would start but stay turning over unless shutting it off so of course I had to turn key to sec click pull starter relay put it back in start the s10 then pull relay so I went out to get a new ignition switch the eltrical side went this morning to fix problem and when taking off the first bottom panel where the emergency brake is I lay it down bump the brake paddle with no key in also in park and the truck fired up so I took out the starter relay and when I hit the brakes the fuel pump is in ganged is this the ignition switch I'm stump
