-   S-10 & Blazer (https://chevroletforum.com/forum/s-10-blazer-20/)
-   -   blazer issue please help (https://chevroletforum.com/forum/s-10-blazer-20/blazer-issue-please-help-34186/)
deadadm1n Jul 8, 2010 2:33 PM
im having a bit of trouble with my blazer. its a s10 v6 vortec 4.3 4x4
has hot and cold air intake on it and a performance chip is the only mods ive done with it so far
here is what its doing, when i start it i have to prime the lines a bit then it will start, the pump is fine and the relays are fine, i drive it for about 30 mins, then after about 30 mins, it starts to give out, when i push the gas pedal to the floor it wants to die down, it looses all power and wants to die, i think its getting to hot and a censor is messing up or something,
does the altitude have anything to do with it, cause its an ohio car, and i moved to colorado and its giving me a bunch of crap,
hopefully someone can help me, thanks in advance
deadadm1n Jul 9, 2010 1:02 PM
ok i just went out to see if it starts up and it started up fine, just when it gets hot it goes out on me i guess....
danb113 Jul 15, 2010 4:54 PM
Call me crazy, but I had a similar problem, and believe it or not it was the gascap.
big daddy 78 Jul 20, 2010 6:37 PM
i have a 1996 blazer that had the same problem on mine it was the fuel pump check your fuel pressure it has to have a minimum of 53 lbs to run the engine correctly
