Brake problems
Brake problems
I was driving the other day and when I went to brake, the brakes were solid. I don't mean firm, I'm talking they wouldn't move at all, couldn't stop. When I tried to stop, the engine sounded like it was going to shut off and almost did a couple of times. When I let off of the brake, the engine ran fine. It did it twice in about a 30-60 second span. I wasn't going fast, maybe 25 or 30 mph. Does anyone know what would have caused this and how to fix the problem? Thank you.
RE: Brake problems
only thing I can think is air in the brake line, this can prevent it from releasing but generally that is when the brakes are locked, I would guess maybe the same but "reverse" effect. do a quick bleed and assure no air or blocks in the line would be my first guess.alsoassuming pads,rotors/drums are fine
RE: Brake problems
That's what i thinking, but would that have made the engine shut off? That's what got me. My buddy was with me and we both thought it might be air in the line, but then were confused by it starting to shut off. It has been driven about 20 miles after that happenedand hasn't done it since then.
RE: Brake problems
ORIGINAL: runge_24
RE: Brake problems
yea, when i went to start it up before all that happened, they felt solid but i didn't think anything of it and they didn't do anything for a couple of minutes after i started, so i don't know what the hell is wrong with it, but i don't want to drive anywhere far with it because i don't want to get going and not be able to start so hopefully i can figure it out. thanks.
RE: Brake problems
Your problem is probably a leak in your power brake booster. It uses the vacuum from your engine to give you power brakes. I had a similar problem when my booster started to fail. Your's may have a leak in the vacuum line or a broken seal. I don't think it is air in your brake lines since that just causes your pedal to go soft.
cmcbride
Avalanche
August 8th, 2012 3:12 PM
