Control Arm parts.
I have a 2000 S10 Base model, 2 w/d 2.2 4 cyl. it needs bushings, upper and lower drivers side. . However the parts for this vary. you can get just bushing, or the control arm assembly (but if you get assembly,you have to buy upper and lower which raises the cost) which is the best economic way to fix this.
Thanks Gramo |
The most economical way to to do this is to replace the bushings only. First make sure the control arms are good and that you get the correct bushing. Make sure you get the ones for rear wheel drive.
also depends if you're doing it yourself or not since replacing the bushings can turn into a bit of a chore sometimes
