electrical gremlin
98 s-10 4.3 4l60e trans and shifts out of park without pedal depressed turn signals do not work already replaced relay and hazards work. The third brake light works fine and when i go to use the turn signal the corresponding lights go dark. It happens when I turn the key on they go on I'm kind of thinking it might be the lockout solenoid.
Brake light/pedal switch?
I checked the pedal switch and replaced it but it didn't help thank you for your insight. I'm going to edit and get everything out there I have diagnosed maybe something will turn up that I over looked.
more than half of the electrical problems in any vehicle is a ground. check the grounds in the firewall and the radiator panel.
Originally Posted by ragnor
(Post 345747)
