Freeze Plugs
I just bought a 2000 Blazer and it has a Freeze plug that is blow behind one of the motor mount. I wanted some advice on the easiest way to replace it. I don't really want to take out the engine and replace them. I didn't know if i could just jack up one side of the motor and replace it. I haven't replaced freeze plugs before. So i am looking for any advice or mistakes anyone has made in the past and learned from them
thanks a ton Matthew |
I would think that if you removed the motor mounts you should be able to jack it up slightly, I'm not sure if you would gain enough access or not.
