headlights don't work
Hi i I'm new to this forum so i apologize if this is in the wrong section.anyways i have an 82 s15 and the other day while driving the headlights cut out and havent been able to turn them back on since what would cause this and where should i start?
Start by checking all the fuses. If they are good then check the headlight switch.
Ok checked all fuses and they are all good.my interior is from a 95 s10 so by headlight switch you mean the one inside you flip on? How do you check if its bad?also when i flip the switch the tail lights come on fine though?i checked all the wires in the harness none look burnt or frayed.so exactly how do i know if the switch its bad?
