Heater in my S10 making a humming sound
Just happened a few days ago, turn the heat on after
starting my truck, and this loud humming sound just takes over. Heat is fine, but the noise is annoying. Could this be my thermostat or something else getting weak? |
Can anyone help please? Sounds like a low bass sound
Does it make the sound when the A/C is on?
Does it make noise with or without the blower on? If so, does it change with blower speed? My car had a panel underneath the dash that encloses the blower motor that would make noise at it had slipped.
It makes noise with a/c on as well, humming noise is louder
when higher speed of heat or a/c turns |
You need to look at the blower motor and fan. Probably bad bearing in the motor or unbalanced fan causing vibration.
I'll try that. Thanks for your help!
| All times are GMT -5. The time now is 1:44 AM. |
