Roof rack solutions for 2001 Crew Cab
Hello everyone.
I was just looking for some advice or direction. I have a 2001 Crew Cab S10. I am looking for some type of roof rack I could use on this truck. I will primarily be using it to carry snowboards and skis. Does anyone have some advice?!? Thanks kindly. Cheers! |
RE: Roof rack solutions for 2001 Crew Cab
Do you want something permanent or one you can take off at a moments notice? JC whitney carries universal ones that just sit on the upper door jamb.
I was thinking something permenant as long as it did not have any negative effects or caused any problems.
But if that does not work then I may just get something removable. Thanks for the info. |
You can get a Blazer roof rack and cut it to size and mount it with screws.
I would have to agree, i have seen several pickups with blazer racks that looked very good, and functioned well, but i ould also check the online replacement sites, because i believe some of the s-10s, possibly the zr-2 came with them, and you may be able to get one of those fairly cheap.
