Wiring----Color Codes-----
82-93 S-10 or blazer
12volts red (there will be 2) + ignition harness Starter yellow or purple + ignition harness Ignition pink + ignition harness Second Ignition white + ignition harness Accessory orange + ignition harness Second Accessory brown + ignition harness Power Lock lt. blue drivers kick panel Power Unlock black/white drivers kick panel Parking Lights+ brown switch or rear harness Door Trigger white - pin or courtesy light Dome Supervision use door trigger Trunk/Hatch Release black + relay under left dash Tachometer white AC coil on top of engine Brake Wire white + at brake pedal switch Parking Brake black - at the e-brake Horn Trigger black - steering column 95-97 blazer or 94-97 S-10 12volts red (there will be 2)+ ignition harness Starter purple or yellow + ignition harness Ignition pink + ignition harness Second Ignition white or pink/white + ignition harness Accessory orange + ignition harness Power Lock lt. blue + either kick panel Power Unlock white + either kick panel Lock Motor gray drivers kick panel Unlock Motor tan drivers kick panel Parking Lights+ brown switch or rear harness Door Trigger white - keyless module Dome Supervision use door trigger Trunk/Hatch Pin tied in with doors Trunk/Hatch Release black/white + switch or keyless Tachometer white AC ECM Brake Wire white + at brake pedal switch Parking Brake black at the pedal Horn Trigger black - steering column 98 + S-10 or blazer 12volts red + ignition harness Starter yellow + ignition harness Ignition pink + ignition harness Second Ignition white + ignition harness Accessory orange + ignition harness Power Lock lt. blue + brown plug at BCM Power Unlock white + brown plug at BCM Lock Motor gray 5wi driver kick panel Unlock Motor tan 5wi driver kick panel Parking Lights+ brown + lt. blue plug at BCM Parking Lights- white - lt. blue plug at BCM Door Trigger - BCM Dome Supervision use door trigger Trunk/Hatch Pin pink/black - lt. blue plug at BCM Trunk/Hatch Release black - purple plug at BCM Tachometer white ac PCM Brake Wire white + steering column Parking Brake black - at the pedal Horn Trigger black - steering column Audio Related (covers all years except for slight variances) Radio 12v--- orange Radio Ground--- black Radio Ignition--- yellow Radio Illumination--- brown Dimmer--- gray Power Antenna--- pink...never in a s10 or blazer...but other gm's LF Speaker +/- tan - grey RF Speaker +/- lt green - dk green LR Speaker +/- brown - yellow RR Speaker +/- dk. blue- lt. blue |
Ignition Black Wire?
Hey Rabbit,
You wrote: 82-93 S-10 or blazer 12volts red (there will be 2) + ignition harness Starter yellow or purple + ignition harness Ignition pink + ignition harness Second Ignition white + ignition harness Accessory orange + ignition harness Second Accessory brown + ignition harness I also have a black wire coming from the ignition switch for my 82 S10 column. Any idea what this is for? I am putting the column in a 49 Chevy Pickup and am doing the wiring myself. Thanks... patioman |
Ground most likely.
Yes black usually indicates a ground wire.
makes sense to me....thanks
need help 98 s10
hey i have a 98 chevy s-10 i had to take the dashboard out because i snapped the plastic pivot for the clutch pedal anyways everything went smoothly back into place but i have a plug that dosnt have a home i work for a nissan dealership and by no means am i stupid.
the plug is pertruding through where the e-brake release is (i havent put that panel on yet) it has 10GA wire with red blue orange and brown i tried alldata and mitchell and still nothing :confused: |
The Revenge (joke)
Old Farmer Johnson was dying. The family was standing around his bed. With a low voice he said to his wife: "When I'm dead I want you to marry farmer Jones."Wife: "No, I can't marry anyone after you."Johnson: "But I want you to."Wife: "But why?"Johnson: "Jones once cheated me in a horse deal!"No money no way in real life,no gold no way in game!
'89 S-10 Blazer under-dash wiring photo?
Hello,
I like the post but have not been able to find what I need. I am in need of a color photo of the wiring harness that includes the various interior lights, ashtray light, glove compartment light and radio wiring for an '89 S-10 Blazer. I've searched online including Autozone's slte and I have not been able to find what I'm looking for. I disassembled my dash and failed to label which wires go where. It's been long enough that I cannot remember, and to complicate matters the aftermarket stereo does not utilize some of the wiring and plugs that still exist behind the radio. I think what remains to be put back in their proper places are 2 or 3 courtesy lights, the ashtray light and the glove box light. If this type of photo is available from a particular manual or book that can be found in a library, etc. I sure would appreciate being aimed in the right direction. Thanks, DBG |
Hey I have a 2012 RG Colorado im tryying to put a turbo timer on but im having trouble with the ignition harness colors can somebody help me? Thanks
wiring colors
If you go to any GM dealers repair shop, they should have a repair manual and they should be willing to give you a photo copy of a page or two.
If you ask and they won't do it, go to another GM dealers shop. This usually works for me. :) |
| All times are GMT -5. The time now is 12:07 AM. |
