P0446 Code on 2000 Chevy Malibu Help?
have a 2000 Chevy Malibu With Engine Code P0446 (Evap emission control system vent circuit)
I changed out the I replaced the Purge Valve Solenoid down by the Evap Canister.
Still same Issue.
Anyone know how to test this?
How do I test the Vent Valve under the hood byt the egr? I think one end has a plastic tube that goes under the car to the evap canister and the other goes to the PCV on the valve cover to the engine.
Ideas? thanks
Still same Issue.
Ideas? thanks
Ok I tested my Evap Purge valve Solenoid by the throttle body with a Vacuum Pump I hooked one end to the side where it goes into the valve cover. it held pressure so its good. Gonna look for a plugged hose down by the evap canister
Aaron@Airlift
August 2nd, 2012 9:33 AM
