TrailBlazer 2002-2009
reduced power light
Old August 31st, 2015, 4:39 PM
dcramer's Avatar
Default reduced power light
my daughters 06 trailblazer with a 4.2 just got a reduced power light. i have checked connections nothing loose. i cleaned the tb, no change. i started it and it will rev to aprox 2200 rpms no more and thats it. i disconnected the connector from the throttle body and give it gas, and it still goes to 2200 rpms. what else can i check?
Old September 5th, 2015, 5:50 PM
dcramer's Avatar
okay, i have replaced the throttle body and the accel pedal and has made no change.i have now notice that if i disconnect the fan clutch when the engine is running there is no change. and i can stop the fan with my hand and spin it in reverse. the only time the fan seems to lock in is when you turn on the air cond, but it still has the reduced power light and rough idle and 2000 rpm max. bad fan clutch? i dont have access to a scan tool or anyway to get the truck to aa shop to pay someone to scan it. we live in the middle of nowhere.
Old September 6th, 2015, 9:38 PM
Wrenchinonchevys's Avatar
You will have to have the codes read. Reduced power can come on for several reasons.
Old September 12th, 2015, 8:09 AM
dcramer's Avatar
okay, got it to a scanner. codes are p2101, p1516, p1682, and an evap code p0449. now where do i need to look? Where is the tac module located on this truck? its a 4.2 ltr.
Old May 25th, 2018, 9:27 PM
brittbarrett94's Avatar
Default Please help!
Currently having exact codes and problems your daughter was experiencing. Did you find out what the problem was?? I've already spent so much money on this issue and nothing is working. Mechanic wants to put new computer in it but before I spend a ton of money on that I'd appreciate if you could let me know if you ever fix this issue??
Old June 23rd, 2018, 12:45 AM
Tony7's Avatar
I have the same problem, mechanic shop change the computer and the pedal position sensor, on my trialblazer 06 4.2 but now the mechanic say "we neet change the throltle body" I'm feel bad
TXPalerider
November 28th, 2019 7:49 AM
dgordon
22
May 1st, 2017 3:47 PM
GForce_2004
August 7th, 2011 2:55 PM
anilll
May 21st, 2011 1:16 PM
Quick Reply: reduced power light
