EVAP service at 60,000 mi?
Old April 9th, 2017, 3:12 PM
tbb2's Avatar
Default EVAP service at 60,000 mi?
My maintenance list has a line item to check the Evaporative Control System @ 60K mi.
Specifically:
-check fuel vapor lines and hoses
-purge valve
I find removal and and replacement instructions in the service manual but nothing on servicing (checking) the EVAP system.
Has anyone serviced the Evaporative Control System ... before it throws a code?
Thank you.
2003 Chevrolet Express 3500 Cargo Van; LQ4 6.0L V8
Old April 10th, 2017, 12:00 AM
well you could do a visual of the lines and hoses and check purge operation with a scan tool.
the check is not required. it will not extend service life. there are no serviceable parts. If something fails, the system will set a code and tell you. then find and replace part.
Old April 10th, 2017, 11:37 PM
Artie1's Avatar
+1 to tech2's advice. Nothing to worry about.
Old February 23rd, 2019, 11:29 AM
tbb2's Avatar
Default ODII threw P0446
I had the local auto parts store hook up their OBDII to see if it said anything about a noise I was hearing in my front wheel that I was suspecting to be the a ABS wheel sensor. It did show C0040 - front right wheel sensor.
It also showed P0446 - evap emission system vent.
The auto parts clerk said that since I had NO check engine light or ABS light ON that these must be intermittent codes and not indicative of a failure.
Opinions?
