No Cruise Control
No Cruise Control
I have been looking thru some archived threads about CC ......I have a 2007 Chevy Suburban 2WD 1500 LTZ (New to me).....The light on the steering wheel comes on however the dash light does not and CC never engages.... checked the fuse (will be checking ALL the fuses over the next couple of days) and just replaced the Brake Light Switch........any other thoughts ??? Thanks
My 07'suburban ltz just started doing same in the last couple days, replaced my brake switch, my #43 fuse under the hood is good so still chasing, if I find anything I will give you a shout
Still no cruise control
few months ago I replaced the brake switch and didn’t help, recently a mechanic said it was the clock spring-replaced it and it
still doesn’t work, any other suggestions?
Clock spring is for the air bag. I do know the turn signal switch COULD have CC wiring through it. I'd suspect mechanical since you have the indication
Replaced clock spring
