Metallic Ticking Every 12-13 seconds
Old October 13th, 2017, 3:31 PM
Ron6519's Avatar
Default Metallic Ticking Every 12-13 seconds
I just finished replacing the lower intake gaskets on a 2001 GMC 2500 Savana van with a 5.0 liter engine. Van has 99800 miles and was used for business until about 2014. I bought the van new. After putting it all back together it started up fine. I walk to the front of the van to check for leaks and I hear this, "click" sound. A while later (12-13 seconds) I hear it again. It's coming from the front of the engine. Sort of on the drivers side. I time it for 4-5 minutes and it clicks every 12-13 seconds.
Oil pressure good. Coolant temperature is the same as always. I changed the radiator hoses and the drive belt as well as the two lower intake gaskets, gas line "O" rings and distributor gasket.
I can't fathom what's happening every 12- 13 seconds that is involved. Took the van out for a 30 minute test ride and it was fine.
Suggestions
Thanks
Ron
Old October 13th, 2017, 9:15 PM
canucklehead's Avatar
Ac compressor cycling?
Old October 13th, 2017, 10:14 PM
Ron6519's Avatar
I'll check tomorrow.
Thanks.
Old October 14th, 2017, 1:52 AM
SnlpeR's Avatar
does it click even after you turn the van off?
exhaust expanding/contracting?
Old October 14th, 2017, 9:57 AM
Ron6519's Avatar
I'm on way out to the van now, but I don't think it clicked when the van was off.
Old October 14th, 2017, 10:31 AM
Ron6519's Avatar
It was the A/C. Once I switched it off, the clicking stopped.
I don't know if this is normal or not.
Is it?
There is no clicking with the engine off.
Old October 14th, 2017, 10:34 AM
Rednucleus's Avatar
probably the normal sound of your compressor cycling on & off
Old October 14th, 2017, 2:19 PM
The compressor cylcles to move oil around the system. Thats why the ac works on defrost....so it gets used during the winter......normal. Just dont leave it on defrost or defrost/floor all the time. Use floor or vent unless you are trying to defog windows, or use ac for cooling. it wont cycle on off forever.....lol
Old October 15th, 2017, 6:24 AM
Teammuir1's Avatar
Teamwork... I like to read that a problem or an issue is Solved.
Old October 15th, 2017, 12:18 PM
Ron6519's Avatar
The issue I'm having is that I've owned this van for 16 years and don't remember hearing the clicking sound before this. Maybe I never had the A/C or defrost on when I've previously in the engine bay. Appreciate all the help for this. I'll just keep monitoring it and see what happens.
