Electrical, clock needs resetting after key is turned off
on
08 Silverado 1500. After I turn off the truck and then turn it back on the clock on the dash/radio goes to 1200. Is it a problem with the ignition or the radio?
on
the radio will have a switched power feed and a constant power feed. if it loses the constant power feed or its grd the radio time will reset. there are multiple radio builds so it hard to give specific information without knowing the radio build code.
the radio may have more than one fuse.
the radio itself may be bad.
