02 chevy express 1500 cylinder head gasket install
Old February 2nd, 2018, 3:45 AM
the Brain's Avatar
Default 02 chevy express 1500 cylinder head gasket install
can cylinder head gasket be swapped w/ engine in van
Vans idels ruff has multiple misfire, low on power when cold lots of white smoke
From exhaust pipe. Using lots of coolant I’ve actually been adding coolant since I bought this van about 2 years ago and 5K miles however according to the somewhat accurate GM water temp gauge engine has never over heated.
The inside of radiator cap doesn’t have the milkie creamie stuff just a good layer of rust, the inside of rad. Is rustie also.
1.can cylinder head gasket be swapped w/ engine in van?
2.or since it hasn’t overheated can I get by w/ sealing fluid poured into the rad.?
Thanks for any good advice.
Old February 2nd, 2018, 3:05 PM
I think that sealing fluid won't fix it. The problem sounds too severe.
Do you see coolant in the oil? Which engine is it?
Yes you can work on the engine in place. Remove the seats (only 4x18mm bolts each) to give yourself some breathing room. It will also allow you to take the doghouse right out of the way.
I would first examine the engine exterior for obvious signs of failure. You might be able to get away with replacing just the lower intake manifold gasket.
Old February 3rd, 2018, 5:25 AM
the Brain's Avatar
Do you see coolant in the oil? theres only a drop of oil on the dipstick so I can't tell I'll take a closer look Which engine is it?
vortex 5.7
yes you make some very valid points by first checking for a cracked block, that mite be fun expoxing it back together if thats even possible?
I have previously tested the intake manifold for leaks by spraying carb cleaner all around its gasket didnt observe any increase in RMPs w/ spary.
there isn't any online van engine swaps videos except for the body removal w/ a lift.
I did see a video of a man lifting the previous era Astro using 4x4wooden blocks to suropt the body,
1.we you say "Yes you can work on the engine in place" are you saying the heads can be removed from block from inside van and though the wheel wheel?
this is still a nice conversion van and adaquite tow vehicah I'd like to spend some time turn so wrenchs and get her up and running,
2.I look at RA for replacement head gaskets this is a totalley stock engine for now,
I'm thinking it would be a good idea to have a combined kit that includs TTY bolts and valve stem seals
w/ 200K on the clock can the rest of the valve train stay as is like reuse the springs retainers keepers ect.? please susgest a gasket kit there are big price differnces and this will be my first head gasket.
after seeing the ytube vids it now makes total sense why she was missfiring.
will I have to clean the block for it visuale inspection for cracks?
edit:Is this true or false some oldtime expert mechanics spary paint or even WD40 on both sides of gasket before torquing down?
Thanks for advice TB
Old February 3rd, 2018, 8:44 AM
StanVan's Avatar
I was always told a thin layer of axle grease on both sides of a head gasket. If nothing else, it will help to hold it in place while you line up the head in reassembly. I've only rebuilt small motors, and never had any issues with doing this.
Old February 3rd, 2018, 9:12 AM
the Brain's Avatar
actualley GM got smart the LS engine has cylinder head aglinement doles.
I've sean videos of folks spraying copper on gaskets before installing but never paint or WD40 seams paint will melt.
Old February 3rd, 2018, 9:24 AM
StanVan's Avatar
I'm not sure what WD is supposed to do in that situation. WD evaporates fairly quickly in normal temps(a day or so). Seems to me it wouldn't last minutes when an engine gets to temperature.
Old February 3rd, 2018, 12:55 PM
If there's coolant in the crankcase, it can show up on the bottom of the oil cap looking like mayonnaise.
I was thinking more along the lines of a coolant leak. I had an intake manifold that became very pitted over time, and the gasket eventually failed and blew out the side. (Vortec 4.3) But I suppose you would have noticed that. (unless problem is inside)
That sounds like a terrible idea.
Through the doghouse opening. Possibly even out the underhood compartment.
If you do end up changing the head gaskets, I agree that it's worthwhile to rebuild the heads using a kit. Nothing wrong with Fel-pro. Bolts come separately.
I've had the same problem as you, only much worse, and the block never cracked. I've never heard of/seen a cracked block. Does that happen often nowadays? The heads might have warped though. You may want to check those and possibly have them machined.
No. I wouldn't put anything on it.
Old February 3rd, 2018, 7:41 PM
the Brain's Avatar
does my 02 express have the L31R engine?
like this https://www.summitracing.com/parts/n...0283/overview/
also what all donor car can I get a 5.7 vortec used engine?
thanks
Old February 3rd, 2018, 8:24 PM
Yes, L31(R)
https://en.wikipedia.org/wiki/Chevro...ock_engine#L31
Old February 4th, 2018, 6:43 AM
the Brain's Avatar
is the 6.0 LY6 390hp engine interchangable like wiring,bolting to the 4L60E trans w/ my 02 era express?
also can the radiator core surport be unbolted to pull engine from front?
