break controler
look into a dealer install oem brake controller . "Some" of the factory units will incorporate sway control using the abs system....a great safety feature. Not sure what year the factory unit started with sway assist but its something the aftermarket units can't do.
Last edited by tech2; May 21st, 2018 at 9:28 AM. Reason: clarify last sentence statement
Something tells me this truck already had a pre-wired connection and someone either decided not to use it or wanted to do it the hard way. My '01 base model which I had to run the brake controller and aux. power wires to the rear had this connection already in the harness. And also, It is 20 or 30 amp fuse for controller depending on how many axles you're running and 40 amp fuse or breaker for aux. power.
