Platform: A-, G-, & W-body
cooling issue leading to cracked radiator
Old August 13th, 2018, 12:29 PM
MattGibson's Avatar
Default cooling issue leading to cracked radiator
I changed the water pump and thermostat in the past year. Temp would stay fine for a while and then it would start to overheat. In changing those things I totally spaced out the fact that I needed to bleed the system. I realized that I prob had some kind of leak but couldn't find it and the head gasket was fine, no water in the oil pan. In trying to bleed the system, I found that there wasn't enough pressure to even get it to bleed. Recently my radiator cracked and I don't wan't to fix it without being sure of what I'm doing. I'm thinking that it never built enough pressure because there was a leak in the radiator that just got worse until the pressure build finally cracked it. Any reason why I should feel differently? Is there any unforeseen problem from not bleeding the system? Thank you in advance
-Matt
Old August 13th, 2018, 12:47 PM
oilcanhenry's Avatar
Thumbs up
-Matt
Its an old car. Its bound to have something go wrong. Had a radiator tank blow up on my old Chevy C-1500, and I take good care of my vehicles. Stuff happens.
No water in the oil doesn't correlate to not having a bad head gasket, BTW. That said, it's always a good idea to check your coolant for days or even weeks after a major repair. Of course, I am not working as an ASE ceritified master automotive technician and I only work on my own vehicles and those of my friends and family, so I have lots of time to do things properly.
Frankly, what I do when changing coolant or a cooling system repair, like a new water pump, is to turn the heater up high, and run it hot with the cap off, until it overflows. Let if cool, and do it again.
Then with the cap at the half way mark, meaning no pressure, I hit the road with a bottle of coolant on hand and get that ***** hot and up to speed at high RPM. Stop, rinse and repeat. Let it cool to ambient temp and keep on filling it to the brim, if needed.
"Its the only way to be sure".
Old August 13th, 2018, 2:52 PM
kevinkpk's Avatar
Radiators about 100 bucks, I'd recommend replacing it. I drive a 96 lumina, replaced the radiator due to leaks 2 years ago.There was an option of 5/8, 3/4 width, I have a/c, and the original was 5/8 so that's what I went back with.
Old August 14th, 2018, 11:07 AM
MattGibson's Avatar
Sounds solid to this car dummy! lol thank you
