Does 2016 Chevy Express 3500 Van have remote start ?
Old August 16th, 2018, 5:31 PM
ChevyVanMan's Avatar
Question Does 2016 Chevy Express 3500 Van have remote start ?
Know on last trucks I had, the truck came with the module, but you had to buy the remotes and they had to program it. Does 2016 Chevy Express 3500 have the module ? If so what is the code to look for ?
Thank you
Kenny
Old August 16th, 2018, 7:33 PM
StanVan's Avatar
"BTV" is the RPO for "Remote Vehicle Starter System" I don't know if the module is there if the code isn't.
Old August 16th, 2018, 7:38 PM
Twscarp's Avatar
Thank you
Kenny
Hi, the 2016 Owners Manual says it could. The RPO Code I found, but not guaranteed is AP3. Probably best to talk to a dealer parts department, maybe get your VIN decoded too while your there.
Old August 17th, 2018, 1:14 PM
Don't see either code, guess module not in there, but will call the dealer to make sure .
Appreciate the comments
Thank you
Ken
Old August 17th, 2018, 10:49 PM
StanVan's Avatar
Don't count it out yet. I have two other lists, that don't have either mine,or Twscarp's code on it. Keep hope alive!
Old August 17th, 2018, 11:24 PM
Artie1's Avatar
Van with remote start would have a microswitch mounted on the hood latch. This is to prevent remote starting while someone could be working under hood. Check for wires there.
Old August 19th, 2018, 10:53 PM
Checked with one dealer and told it doesn't have the module . Was also told GM won't provide the programming each of the vehicles need to even program it " not to their Dealers ". If it isn't enabled when vehicle is bought, tough.
Will look for switch however , it has a switch to turn on under hood light when hood goes up though.
Thank you
Ken
