Chevette
Lol that's the whole thing. About 10 years ago my dad built a homemade tractor and used a chevette motor. Nobody knows what year it came out of and when he passed away a couple months ago I inherited it.. it will run but the vacuum lines I was told a all screwed up. Only runs if you keep pumping the gas petal. Carb has been cleaned and there are vacuum lines unhooked.
You should post this query on General Tech, BTW.
Not sure why they were unhooked. Dad had dementia and he was always frigging with it. Didnt have the heart to tell him to leave it alone. I asked earlier a question as to where to post it BTW
Look for ports on the engine that should have a hose attached but do not. If you can't find any then plug the ends of the hanging vacuum hoses and see if this helps the engine to run better.
This old-style device needs to be connected to your carburetor by a small hose, for your motor to operate correctly.
Your Chevette motor was designed to work with BOTH ignition advance devices, when it was installed as OE, in the old Chevette that it was pulled from. Barring that, plug any and all open vacuum hoses, as "oldchevy" suggested here.
