2007 turn button 4wd
Old September 17th, 2018, 2:23 PM
joey85's Avatar
Default 2007 turn button 4wd
When backing up and turning right the 4wd will go into 4low when i start to move its in 2hi though. 4wd low indicator is on and you can feel front end bindning (4x4 binding). Anyone have similar issue
Old September 17th, 2018, 6:25 PM
oilcanhenry's Avatar
Probably a bad transfer case encoder....if you are lucky. Do you hear any strange noises from the transfer case area?
Old September 18th, 2018, 6:37 AM
joey85's Avatar
no strange noises at all and other wise drives very very well
Old September 18th, 2018, 3:34 PM
Has the transfer case had a fluid change done or levels checked?
