Chevrolet Malibu
2009 Malibu radiator fan and ac fan issue
Old November 15th, 2018, 5:35 PM
Nakeem Forte's Avatar
Default 2009 Malibu radiator fan and ac fan issue
Temp hand slightly creeping up at idle. Seems like neither fan is turning on. Could someone explain to me how the system works please. relays and details and help with what may be my issue. Ac on hood popped no fan running. Any help would be appreciated.
Old November 17th, 2018, 1:02 PM
oilcanhenry's Avatar
Not sure what you meant by Ac on hood popped. Can you elaborate?
Old November 17th, 2018, 2:48 PM
When the air condition on and the hood of car up/open. Fan should be on when a/c is on but it is not
Old November 17th, 2018, 10:49 PM
I'd wager your cooling fans are in working order, but not getting power. Most likely the cooling fan relay has gone bad.
I'd check all the wires for any corrosion or other issues as well, including the wires going to your coolant temperature sensor.
Old November 18th, 2018, 8:41 AM
Thank you getting it check out now
Old November 18th, 2018, 1:29 PM
They are say fan assembly but I doubt pep boys even really tested anything
Old November 18th, 2018, 7:22 PM
I would not trust Pepboys service department for anything. Bad Juju many years ago with those morons.
I'd try jumping some power directly to the wiring connector or do a continuity test yourself. That fan assembly is about
$90 dollars USD from Rock Auto..
