Chevrolet Equinox
Platform: Theta
outside air temp
Old December 8th, 2018, 5:13 AM
musicman's Avatar
Default outside air temp
My outside air temp is not showing up on my 2017 Chevy Equinox. How do I get it back on?
Old December 9th, 2018, 11:41 PM
oilcanhenry's Avatar
Pretty sure the termister would be located near the very front of the vehicle. Once mine ever goes I wont give it a second thought, frankly.
Old December 9th, 2018, 11:56 PM
is the display showing dashes instead of a number -- ?
Old December 10th, 2018, 5:11 AM
musicman's Avatar
No it is not
Old December 10th, 2018, 5:14 AM
musicman's Avatar
They replaced the ambient temp. sensor and this did not help
Old December 10th, 2018, 8:48 PM
what is it displaying? Is there a code set? It may not be a powertrain code but rather a body code so a cheap code reader will not access it. check all modules.
Old December 11th, 2018, 4:04 PM
musicman's Avatar
It is showing Day, Date and Time on the Chevy My Link screen. Is there a fuse just for the outside air temp. I had a small fender bender on the right side that is why the replaced the broken temp sensor. Could it be the wrong ambient temp sensor? Thanks for your reply.
Old December 11th, 2018, 8:54 PM
no for a fuse...the sensor is fed power from a module. So its missing from the screen since an accident? if yes, go into set up and see if you can change the set up
Old December 14th, 2018, 6:56 AM
musicman's Avatar
Thank you, I tried to do a new set up but did not work . Still no temp reading on screen. I also can not seem to find out how to change the temp reading on the auto ac from cel. to far.
Old March 28th, 2019, 3:32 PM
musicman's Avatar
The outside Temp is finally fixed, also the temp settings. Chevrolet had to do a Harness repair after they had to R & R bumper and R & R battery fuse block under the hood to gain access and repair the Harness. It was covered by the Warranty. Thank you.
