Platform: Delta
Also Check out CobaltSS.net
Front left wheel makes loud vibrating/grinding noise when I turn left
Old December 10th, 2018, 6:55 PM
brainy19's Avatar
Default Front left wheel makes loud vibrating/grinding noise when I turn left
I drive a 2008 Chevrolet Cobalt LT. For the past couple weeks, whenever I turn left going at about 40 MPH or faster, I would hear a loud vibrating/grinding noise. It's quiet when I turn right tho. The noise starts even if I make a slight turn (when changing lanes for example).
Any ideas what it may be? I suspect it is the wheel bearing, but I would like a 2nd opinion please.
Old December 11th, 2018, 12:31 PM
SBchevyfan's Avatar
Most likely a wheel bearing but could also be brakes. Pull the front wheels and check the wear on both sides to make sure the wear is even, not a hung up caliper. Any warning lights coming on?
Old December 12th, 2018, 3:58 PM
brainy19's Avatar
No warning lights
Old December 12th, 2018, 8:53 PM
Kazoocruiser's Avatar
Location: Currently the Candian Gander is wintering over in New York.
My vote is that it is a hub bearing
Old December 13th, 2018, 1:17 AM
brainy19's Avatar
Checking the brakes sound easy and I can take off the brake pads and brake disk to check the wheel bearings, but what signs are there that the wheel bearings need to be replaced?
Old December 13th, 2018, 8:36 AM
How many miles are on the odometer?
I did a search on google for "how to determine if a hub bearing is bad"
You might get your answers faster there, than waiting for answers here.
Old December 14th, 2018, 11:26 AM
SBchevyfan's Avatar
Very likely it's the bearings. You can grab the wheel with the front end off the ground and pull on it in different directions and check to see if there is any play. Also, don't just replace one bearing if that's what you decide to do. Make sure you replace both front bearings at the same time.
Old December 15th, 2018, 5:40 AM
I would also suspect bearing.
Old December 16th, 2018, 12:55 PM
brainy19's Avatar
Thanks for the feedback everyone!
