2002 s10 engine miss but no code
Old December 19th, 2018, 9:20 AM
William Dibler's Avatar
Default 2002 s10 engine miss but no code
4.3L New fuel pump,filter, plugs and wires, cap and rotor.
my truck has recently started to miss, but not throw a code until I drive it but it only flashes and doesnt store it. It runs like a Ford anyway I checked plugs and wires cap and rotor and did a compression test which all came back fine. Idle is rough as it shudders a little. When I drive it, it runs rough bouncing rpms. I'm running out of ideas since theres no code for me to go off of.
Old December 21st, 2018, 10:07 PM
a-ron's Avatar
I would see if you can get your hands on a scanner that will let you view real- time data and see what cylinders or cylinder is misfiring so you can narrow it down! Could also be a timing issue! I did have one that the timing chain tensioner went bad and the timing jumped
