Notices
Silverado DIY and Useful Threads This section is for Do-It-Yourself articles and other informative FAQ threads. If you would like to submit an article, contact a member of staff!
no rear parking lights, low current... Switch on, No brake lights, no tail lights?
Old November 8th, 2017, 4:48 PM
Newly Registered
Eyecandonething4u's Avatar
Default no rear parking lights, low current... Switch on, No brake lights, no tail lights?
1994 Silverado, after market electric trailer brake mechanism installed by U-Haul. Replaced brake light switch, ignition switch, (not key switch), all rear bulbs replaced, all ground wires connected, checked thoroughly every lighting wire from the steering column through out the whole truck for continuity, and or other issues, (all good). had a stop light issue, the third brake light was grounding out and blowing stop light/ flasher fuse with a touch of the brake pedal. Now the truck has no parking lights or brake lights at the rear, after switching on the Head light switch. with the turn signal/wiper/cruise control switch engaged, one signal(left) flashes quickly and the right side is also flashing dim at the same time. Any help or same problem dealing with this issue, please help me resolve. Thank you!
