"Check CD" Error
I have a 2007 LTZ Crew NBS with the 6 CD disc changer that is throwing a "Check CD" error. Any ideas?
RE: "Check CD" Error
using a burnt cd? could be the format that it was burnt. Try using a different program to burn the disc. Also check the cd for the abvious, fingerprints, scratch, dirt etc.
If it happens with store bought cd's, and they are clean, you'll need to bring it into the dealer for a new radio |
They are burnt CDs that i have in there but i have been using them all year long without issue. The CDs will not eject at all. It just throws the code and send me back to the radio.
you'll need to have a new radio put in it. The cd Mechanism has crapped the bed
There is a bulletin to reprogram or reflash radio. Have the dealer look it up. I have the bulleting number at work, I will post it tomorrow.
Get it to the dealer quick,dude, my CD changer got replaced under warranty.
I took it to the dealer and they did a reprogram. This is what was on the invoice below. The dealer service scheduler could not explain it.
R0759 Radio Reprogramming with SPS FC: 80925 Also, i have a high pitch noise that is coming from the radio. You can only hear itwhen other noise does not drown it out. My brother has an 07 NBS and his does it as well. Is this standard on all? |
Noise is proberably the fan in the radio. I have yet to see them replace a radio for that. Normal operation. Have the GM Shop foreman ride with you if it is too loud.
