chevychick24 |
August 29th, 2009 11:16 PM |
00 silverado 4x4 2500 (gas) help please
hi,
so heres my problem i went on a camping trip and on the way there driving two hours my truck was fine and only used an 8th of a tank, then on the way back she started running rough and resisting from take off and drank over a half of a tank so then she started throwing out codes saying she is misfiring on injectors 2 and 4 so i changed those two and the 02 sensor one the bank side it was misfiring on and no change the engine light didnt come on as much but still having the rough idle like she wants to die and the resisting from take off its like she is now starving of gas and all i can think of is that my ecm has gone cause i checked and pulled everything apart the fuel lines the fuel pump and changed the 02 sensor the two injectors that were misfiring the fuel pump and nothing the injectors helped a little just when it comes to the engine light not coming on as much, i want someones advise cause i have got a ecm lined up and i want to know other people opinions if thats ok. i have heard of this happening before to an 03 model half tonne. please give me your feed back
thanks
